It`s only a 223
  • The Smythe Meister
    • Jan 2019
    • 6248
    It`s only a 223
    Evenin` Chaps.....
    So,as said in my other thread,i`ll be doing a little build alongside my 1/9th Zundap combi.....
    and i`ve decided to go back to WW2 German again,with this......
    It`ll be more or less OOTB..... probably familiar to many of you,it is,after all,a staple Tamiya kit.... couple of sprue pics.....
    Pretty standard fare... and first stage completed,typically straight forward and enjoyable:thumb2:.......
    More tomorrow,anyone who fancies tagging along will be more than welcomed:nerd:,
    Cheers for now,
    Andy
    • 15650
    Hi Andy
    That's a nice kit. I built it many years ago and I seem to remember it as a straightforward build.
      • Jan 2019
      • 6248
      Originally posted by Jim R
      Hi Andy
      Nice one Jim:thumb2:,
      Yes,from what i`ve done so far,and looked at further ahead,it looks to be a doddle of a build....
      .......apart from that horrendous Black mesh that Tamiya used to provide for Grille coversoop: of course!!:tears-of-joy:
      Andy
      • Allen Dewire
        • 4741
        • Allen
        • Bamberg
        And don't forget the jerry cans with only 2 carry handles instead of three, on top Andy...........So wrong and need to be replaced............I'm in for this one Bro...........
        Allen
        • scottie3158
          • 14198
          • Holbeach
          I built one of these not long ago. It is typical Tamyia no issues at all.
          • Steve Jones
            • 6615
            Off to a great start Smiffy. Get some help in and you will soon have those jerry cans sorted LOL
              Those are the wrong type, though — they’re the British copy
              Here is some more inspiration, I hope:
                • Jan 2019
                • 6248
                Allen
                Received and understood Allen
                It does amaze me the sheer amount of different "styles" of Jerry cans you see from various manufacturers... From the correct to the down right ridiculous,( I.E. just one huge,solid handle),and everything in between!!
                Andy
                  • Jan 2019
                  • 6248
                  Nice one Scottie
                  I suspected as much,good to have it confirmed though mate!
                  Andy
                    • Jan 2019
                    • 6248
                    [ATTACH]450642[/ATTACH]
                    HA!! Nice one Steve
                    I hope they're empties!!
                    Andy
                      • Jan 2019
                      • 6248
                      Originally posted by Jakko
                      Those are the wrong type, though — they’re the British copy :smiling3:
                      Yep,I noticed that too!
                      Thanks for those vids.... A great help indeed mate :smiling3:
                      Andy
                      • Airborne01
                        • Mar 2021
                        • 3940
                        • Steve
                        • Essex
                        Received and understood Allen :smiling3:
                        Andy
                        Since the 70's, at least, water jerricans have been supplied in black or green plastic with a large single, central, handle! All had large, central, screw outlets!
                        Don't know if they still come that way!
                          • Jan 2019
                          • 6248
                          Yep,good point Steve
                          More recent ones certainly were, although it's the WW2 kit subjects that I was predominantly thinking of
                          Andy
                          • PaulTRose
                            • Jun 2013
                            • 6451
                            • Tattooine
                            funny enough i watched an interesting vid about jerry cans only a couple of days ago
                            Per Ardua
                              Most of that is because in the 1970s, some manufacturers (﹡cough﹡Tamiya﹡cough﹡) took what back then were more or less acceptable shortcuts, like moulding jerrycans in two halves with a handle on each side. Today, modellers expect them to be slightly more accurate, but as those same old kits remain in production, you will still encounter those older types.
                              You can just see the W↑D marking that’s been stamped into the jerrycans: this is a picture from a British factory
                              It does nicely illustrate, though, the reason the American jerrycans were not as good but quicker and cheaper to make: welding the two halves of the jerrycan makes them perfectly watertight and very strong, but look at all the people needed to do that. Because the Americans considered the idea sound but the execution to be too complicated, American cans had two sides and a bottom that were seamed together rather than welded, which is quicker but they would split much more easily at the seams.
